Replacing clock light
Old Aug 31, 2005 | 04:22 PM
Grayfox's Avatar
Grayfox
Default Replacing clock light
The light in the clock of my 99 3.2 TL burned out, and my dealer quoted a price of $125 to replace it, claiming that it involved 1-1/2 hours of labor. Is it possible to do this myself? I'm no mechanic, but fairly handy with tools.
Thanks
Old Sep 1, 2005 | 06:36 AM
98CoupeV6's Avatar
98CoupeV6
lots and lots of fail
You have to remove the instrument panel.
Instrument Panel Removal/Installation
NOTE:
When prying with a flat-tip screwdriver, wrap it with protective tape, and apply protective tape around the related parts, to prevent damage.
Take care not to scratch the dashboard and related parts.
Tilt the steering column down.
Remove the steering column upper cover.
Remove the instrument panel (A).
Remove the screws.
Gently pull out along the bottom to release the lower clips (B), then along the top to release the remaining clips (B and C).
Disconnect the TCS/cruise control main switch connector (D), moon roof switch connector (E), select/reset switch connector (F) and hazard warning switch connector (G). Without navigation unit, disconnect the clock connector and climate control unit connectors.
Install the panel in the reverse order of removal, and make sure each connector is plugged in properly.
Clock
Replacement
Remove the instrument panel.
Disconnect the 5P connector (A) from the clock.
Remove the two mounting screws (B) from the clock.
Remove the clock from the instrument panel.
If necessary, replace the bulb (C).
An hour and a half :lmao:
Old Sep 1, 2005 | 10:10 AM
Grayfox's Avatar
Grayfox
Default Great Instructions
Thanks very much for the detailed instructions. But since it looks like it would take me at least a day and involve the possibility of terminal frustration, I think I'll pay the $125 and let the dealer do it. (swallowing a portion of pride, since I ranted at the service manager about gouging)
Old Sep 2, 2005 | 06:30 AM
98CoupeV6's Avatar
98CoupeV6
Are you kidding me? It would take you about an hour, tops, for a first timer. All you have to do is remove one single plastic piece.
