help with gauge istallation?
Old Aug 14, 2005 | 12:26 PM
partspro64's Avatar
partspro64
Default help with gauge istallation?
I installed a set of gauges on my 96 accord and they dont work. The fuel gauge goes straight to full.The speedo rests at zero but when you start the car it jumps up to 30mph and proceeds to work from there.The tach moves very lazily between 2 and 4k rpm. The temp gauge doesnt move at all.I dont know what else to do? Someone please HELPP!!!!!!!
Old Aug 14, 2005 | 03:58 PM
ej8_hamazaki's Avatar
ej8_hamazaki
いじわる りゅう
Didi you connect them correctly? Check it again.
Old Aug 15, 2005 | 11:29 AM
partspro64's Avatar
partspro64
Yes,there are only 3 plugs and they do not interchange
Old Aug 19, 2005 | 09:19 AM
hoyoung02's Avatar
hoyoung02
HEAT:Shift_TechkaV
check the connections on the harnesses.
push in all the wires into the harness a bit.
reset your ECU by disconnecting the negative power for 1 min or so, and see if it still does it.
if it's not the ECU, then it's the cluster gauge problem.
Old Aug 19, 2005 | 10:09 AM
mberndt's Avatar
mberndt
Ummm, ok....
What kind of gauges??
Stock gauges from the same year and model car??
sounds like it's hooked up wrong, or it's the wrong unit...
where did u get it?
Old Aug 19, 2005 | 10:32 AM
Special K's Avatar
Special K
Most likely a gauge cluster problem. I had the same thing on my civic when I swapped out my stock one for one with a tach.
Old Nov 15, 2005 | 05:57 PM
2001 Civic's Avatar
2001 Civic
i can prolly help you with the speedo and the fuel ...full your tank up remove you fuel needle and turn your car on and wait a few sec and replace it at the full mark. The speedo remove the needle turn the ignition on your guage sensor thingy should be set at "0" then . Replace the needle at the "0" mark try the same for tach and your temp needle might be set in to tight
Old Nov 16, 2005 | 05:30 PM
Arashi666's Avatar
Arashi666
kinda off topic... but I wanna change the guages on my '97 CL and I was wondering if anyone could tell me how to get to the panel to change them out, and all the steps neccesary to fully swap um out
