How to install greddy evo2 catback system
Old Jul 19, 2005 | 05:53 PM
italia8287's Avatar
italia8287
Default How to install greddy evo2 catback system
Finally got my Evo2 delivered today just to realize that they dont give you an installation guide. So im just wondering if someone could help me get some information on how to install it on a 2000 Civic Ex. Thanks!
Old Jul 19, 2005 | 05:54 PM
ED9man's Avatar
ED9man
driver
It should be pretty straightforward
Old Jul 19, 2005 | 05:56 PM
italia8287's Avatar
italia8287
You would think haha but just not sure because it came in 3 sections and i know where the muffler goes obviously but not where just the piping goes and where the section with the resonator goes. Or do I just see what fits where??
Old Jul 19, 2005 | 06:20 PM
Provocateur's Avatar
Provocateur
On permanent hiatus
Take off the stock exhaust and then compare the pieces of the Greddy Evo to it. Piece it together on the ground and then install the pieces, section by section. There is only one way it can go together, so keep trying, it isn't that hard.
Old Jul 19, 2005 | 06:56 PM
oei28's Avatar
oei28
It's like solving a puzzle, if it doesn't fit, you did it wrong, if it fits, and everything bolts on, you're set.
Old Jul 26, 2005 | 09:37 PM
djyoshi's Avatar
djyoshi
i've installed it in my 96 integra gsr. it wasnt that hard (the only hard part was climbing underneath and working in small quarters using jackstands). i took off my old exhaust, and lined it up with the greddy one and matched the bend in the pipes.
here's a helpfull hint...
spray wd-40 on the nuts and bolts and let it soak in for a while. it'll make it easier to undo them.
also use a box or a jackstand to hold up the catalytic converter while uninstalling the old muffler so you wont bend your exhaust headers or rip your o2 sensor wires out.
also the greddy exhaust end was a bit short with my rear body kit on. so i had to go to a muffler shop and they extended the pipe (before the muffler). i think it only costed around $50 for the job.
hope this helped.
