Honda Accord 97, door lock cylinder install
Old Jul 1, 2005 | 07:10 PM
vtestiler's Avatar
vtestiler
Default Honda Accord 97, door lock cylinder install
Hi everybody, where can I get instructions on replacing door lock cylinder on Honda Accord 97. I have a Haynes repair manual, but it doesn't have any pictures on door lock replacement. I couldn't find the way to remove outside door handle. In the manual they refer to some bolts, but without good pictures it is not very clear where they are.
Thanks
Old Mar 27, 2008 | 06:23 PM
UGABulldog73's Avatar
UGABulldog73
I'm having the same problem myself. If anybody has an answer, I'd sure like to hear it!
My 2001 Honda Accord got side-swiped while parked on the street. I had to replace all the doors on the passenger side with doors from a junk yard. They work fine, except I can't get the stinking lock mechanism out of the replacement door, to put the lock mechanism in from the old door.
Any advice would be greatly appreciated.
Old May 5, 2008 | 06:04 PM
IkeRay's Avatar
IkeRay
Aka #5
you'll have much better success in posting this in the honda accord section, and then starting a new topic stating the same year models. the models changed in 1998, so it might not be the same way to remove them in a 1997 as it would be in a 2001.
