Clutch Issues
Old Jun 21, 2005 | 01:46 PM
pragl's Avatar
pragl
Default Clutch Issues
I have a 1998 acura integra with 205,000 miles. over the past month i've had some chatter in my clutch when in gear and finally yesterday all the pressure went out in the clutch and i couldn't get it in gear. The clutch never slipped but now i just cant get it in gear unless i turn the car off. Now, when i turn it off and put it in gear the car will move even iff the clutch pedal is pressed to the floor, furthermore there is absolutley no resistance in the clutch/ no pressure. Is this a master cylinder issue/ slave cylinder issue/ or clutch issue. I was told to look for any leakage under the car but i didn't see any can someone help me?
Old Jun 22, 2005 | 04:53 AM
JimBlake's Avatar
JimBlake
Has the fluid dissappeared from the clutch reservoir? If so, it must have gone someplace. Check if it's soaked into the padding under the carpeting below the pedal.
If the fluid is gone, you may get away with filling it & bleeding out the air. But that doesn't fix the leak.
It could also be something broken at the throw-out fork or the pressure plate. Check out the throw-out fork, whether it's moving properly.
Old Jun 23, 2005 | 09:17 PM
ludepimp's Avatar
ludepimp
were is the cluch fluid
Old Jun 23, 2005 | 09:21 PM
Provocateur's Avatar
Provocateur
On permanent hiatus
In the clutch reservoir.
Is that a trick question? :thinking:
