1996 Honda Accord-replacement turn signal
Old Jun 13, 2005 | 01:55 PM
Umamel2003's Avatar
Umamel2003
Umamel2003
Default 1996 Honda Accord-replacement turn signal
HELP! Does anyone know how to replace the front turn signal in a 1196 Honda Accord, I have lost my user manual, and it seems immpossible to get to the bulb to replace it???
Old Jun 13, 2005 | 05:56 PM
Stall?'s Avatar
Stall?
Teh slow
1196 Accord, get the axe out and start choppin.
Those wood fenders rot after a while, especially after 809 years.
Btw to replace the bulbs, just cut the corner out and jam a light in there, if these two dont sound good to you, time to start searching and stop being lazy.
Old Jun 16, 2005 | 08:39 PM
fac90's Avatar
fac90
Are you talking about the corner or bumper turn signal? The corner lense has to removed. There is a screw and you have to pull the lense off. It may be difficult to pull the lens out, but it will come out with some patience.
The bumper lense has a screw which is hidden. Facing the lense, at each inner side, you can see a screw through an access hole. Be careful not to lose the speed nut which the screw fastens to, otherwise the lense will not hold. The speed nut is like $1, but a trip to Autozone will be required.
