Rear LCA bushing size
Old Jun 13, 2005 | 01:25 PM
robert f thomas's Avatar
robert f thomas
Default Rear LCA bushing size
I ordered bushings for my disc swap. The new bushings are 30mm diameter. Trouble in "River City"!!! I pressed out the LCA endpoint bushings and they are 35mm diameter!! TOO BIG!!!
The hubs have ABS gears on them. I ordered 91 CRX LCA bushings. Now I know I was wrong. ABS came out in 92. Does anyone have an idea what year vehicle I must use to order LCA bushings for a 35mm size opening?? Thanks bunches. RFT
OK found an informed individual who indicates the bushings I seek come from an Integra. So I have to order integra bushings. So the entire trailing arm/ rear hub assembly comes from an Integra. Ha Ha joke is on me!! RFT
