Installing Foglights
Old Jun 24, 2005 | 04:41 PM
ej8_hamazaki's Avatar
ej8_hamazaki
いじわる りゅう
since your from chicago, i'll help you.
Old Jun 25, 2005 | 07:24 AM
VPUPPY's Avatar
VPUPPY
ok, don't run the fog light straight to a fuse or wire that supplies voltage to your lights. you NEED to get a relay to safely do this. you should wire the relay so it gets activated when the parking lights are on, then that same relay would active a relay for the fog lights. what kind of fog lights did you get? are they OEM ones from honda or aftermarket?
Old Jun 26, 2005 | 02:18 PM
VPUPPY's Avatar
VPUPPY
here is a generic hook up of the relay. if you have any questions, post back here. those terminal numbers you see should correspond to a typical automotive relay. the bottom terminal is where you have to choose the activation type for the fog light relay. if the fog light relay is activated by 12+, then you want this relay to send 12 (+) to the fog light relay. if the fog light relay is activated by ground (-), then you want this relay to send it ground. you MUST choose one or the other, not both. make sure you verify the terminal numbers with the relay you buy. visit www.the12volt.com for more information on how relay's work. remember, this is only advice. i take no responsibility in any incorrect wiring you do.
