Problem with after Axle change
Old Feb 2, 2005 | 03:05 PM
myvigor's Avatar
myvigor
Default Problem with after Axle change
Things have been done:
1)
Changed front-right axle and bearing
2)
Replaced all 4 brake Pads.
Problems experienced immediately after:
What we found thereafter was that the car started to shake badly once it shifted into a gear. It happens at traffic light as well. Once car starts moving in a motion, it goes smoothly, no problem. I sent car back to the car shop, and he ended up adjusted timing belt. But the problem still exists, did not get any better. I now even face a metal rattling sound on a bumpy road.
What could this be? I don't want take it back to the original shop as he was clueless.
Thanks, mark.
Old Feb 2, 2005 | 05:34 PM
12yearhondatech's Avatar
12yearhondatech
I know this sounds wierd but you may have knocked a vaccum hose off.
Old Feb 3, 2005 | 09:10 AM
sophal's Avatar
sophal
Mr. Lover
try getting the car on a hoist and see where the shim is comming from. i figure sometime is loose.
Old Feb 4, 2005 | 07:08 AM
Devil's Sol's Avatar
Devil's Sol
Tired of being slow
i don't know how much your car is shaking, but my car vibrates and makes a rattling at low rpms and all it is on my car is a loose heat shield that is coming in contact with my exhaust.
Old Feb 4, 2005 | 07:33 AM
MTEng's Avatar
MTEng
[QUOTE=myvigor]I sent car back to the car shop, and he ended up adjusted timing belt.QUOTE]
There is no adjustment to the timing belt.... The guy's a crook.
Take it somewhere reputable and have them diagnose.
Old Feb 4, 2005 | 01:01 PM
Tankard's Avatar
Tankard
[QUOTE=MTEng]
Sure, you can tenision the timing belt with the tensioner;however, that would have nothing to do with the car shaking.
