Power Steering Fluid Air Bleeding 03 TL-S
Old Feb 1, 2005 | 08:41 PM
crx2727's Avatar
crx2727
Default p/s steering bleeding
p/s bleeding steps
File Type: pdf
Old Feb 2, 2005 | 07:25 AM
acutee's Avatar
acutee
Default Power Steering Grease
I just checked with Acura yesterday and the tech said they no longer carry the grease since it was used to fix the power steering problem long time ago. I will live with it the way it is for now since there is no more grinding noise after one drain and refill. If the noise comes back, then I will check with Honda. I appreciate all the help you all have provided.
PS: Anyone got this kind of grease from Honda lately?
