how to rebuild cv axle
Old Jan 29, 2005 | 02:15 PM
mark4jon's Avatar
mark4jon
Default how to rebuild cv axle
Would like to kow if the right cv axle on a 90 accord can be rebuilt.
Would appreciate if there were some pics and how to instructs.
Old Feb 1, 2005 | 12:06 PM
JaVa_230's Avatar
JaVa_230
just replace it they are pretty cheap.
Old Feb 1, 2005 | 12:14 PM
westcoaststyle's Avatar
westcoaststyle
Still here... sorta...
Exactly, why would you want to? The axles for my teg motor/tranny are only $60/ea from NAPA with a lifetime warranty after core. Just get a new one. h:
Old Feb 1, 2005 | 05:05 PM
hype8912's Avatar
hype8912
Dr. Klaw
I recently just did my passengers side axle and it was $57. Go buy a rebuilt one and be done with it. It really was like $123 and then you get $60 back when you turn the core in. Also. you'll probably have to rent the tie rod end seperator from autozone. They charge $16 to rent it when you pick it up then when you bring it back they give you the $16 back. Look for the service manual online. Its out there on a honda website. The best instructions I had were from that. The haynes manual sucks.
Old Feb 4, 2005 | 01:05 PM
Tankard's Avatar
Tankard
Exactly as posted above. The only time i do anything with my cv joint is if the boots broken and it has not started popping. I repack it with grease and replace the boot. If it's popping already, get another whole cv joint. Also, you don't need that tie rod end seperator if you do it like i do. Whack it with a heavy mallet or huge hammer, and it seperates every time.
Old Feb 6, 2005 | 03:31 AM
SP00NFed's Avatar
SP00NFed
FuK JDM
I agree
Old Feb 11, 2005 | 10:53 AM
miahmouse's Avatar
miahmouse
Not every time. I've beaten the life out of my front LCA to no avail. if you turn the wheel (to the left in your case) you can put the square part of a long pry bar inbetween the knuckle and the arm, and jump on it it'll pop loose every time in seconds....
