88 CRX....door problem....help
Old Jan 8, 2005 | 11:11 PM
AllAccords88's Avatar
AllAccords88
Default 88 CRX....door problem....help
I am probably buying a crx tomorrow, and the only thing wrong with it is that the passenger door is really loose. like it goes down like 3 inches when you open it, but it does close. Is there anything i should look at or would just replacing the door fix this problem?
Old Jan 8, 2005 | 11:27 PM
Provocateur's Avatar
Provocateur
On permanent hiatus
Check out the hinges. They may be really loose or the threads on either the door or frame may be rusted out. It is most likely the hinges, so inspect/replace those before you consider the whole door.
Old Jan 8, 2005 | 11:30 PM
AllAccords88
ok...the guy said he had it set up for drifting, could the frame be bent? Thats what my dad said he thinks it would be, but he hasnt seen it...is that common?
Old Jan 9, 2005 | 09:51 AM
AllAccords88
ok...im going to buy it in abuot 2 hours...anyone know of anything else i should look at?
