Clear corner lights
Old Jan 6, 2005 | 06:16 PM
DR occA's Avatar
DR occA
Default Clear corner lights
ANY suggestions on EASILY getting the factory corner lamps out on a '97 Accord SE. I broke the arm that screws down off of the first one i tried, but im trying to save them for seasonal purposes. THANKS!
Robb
Old Jan 6, 2005 | 10:00 PM
DaNnYsEvEn's Avatar
DaNnYsEvEn
ThInK PiNk!
im not sure about this but i seen it in the owners manual. you already broke the visible screw wich should be on top. well in the manual it shows that there is a screw between the headlight housing and the corner light somewhere. if thats the way to do it then your going to need a really small screwdriver. once again i havent tried to do this so i dont know. i just know this by looking at the picture that was on the manual. its worth a shot. im going to take mine off later on today and put the halo headlight housing with the black backing.the headlight housing and corner light in one. looks pretty cool. well good luck
