rear disk conv. on 88 crx
Old Jan 3, 2005 | 12:49 PM
TnCRX's Avatar
TnCRX
'88 B18a1 CRX
Default rear disk conv. on 88 crx
Is it possible to take the rear disks from an 86 integra and put them onto m 88Crx. I know that I have to pull off the brake system, lower control arm, and the brake balancer from under the hood. Is that everything? I was just wondering because the junk yard around here just got in an integra. Any info would be great. Thanks.
Chris
88 crx b18a1 swap
lots of goodies
Old Jan 3, 2005 | 03:32 PM
SonicGSR98's Avatar
SonicGSR98
Shadow Lurker
86 Integra will not work on your beast because the 86-89 integras have a "dummy" axle set up in the back. you'll need the rear discs from a 91 CRX Si or the whole rear trailing arms from a 90-01 Integra or any other 92+ Civic that has them.
