cv axle
Old Jan 1, 2005 | 08:48 PM
cooter1's Avatar
cooter1
Default cv axle
Can anyone tell me how to change my CV axle on my 91 Integra LS. Don't have the money to pay the shop down the street to fix it this time
Old Jan 1, 2005 | 10:47 PM
Provocateur's Avatar
Provocateur
On permanent hiatus
Which side?
Old Jan 2, 2005 | 02:26 AM
cooter1's Avatar
cooter1
Default CV axle
The passenger side
Old Jan 2, 2005 | 03:19 PM
Provocateur
On permanent hiatus
You need to remove the wheel, undo the axle spindle nut with a big ass breaker bar, remove the suspension fork and the lower ball joint. Pull the hub back and pop the axle out of it. They use a screwdriver to pry the axle out of the tranny. Pop new one in and reverse the order of steps.
Oh, I forgot that you need to drain the tranny fluid beforehand.
Old Jan 3, 2005 | 04:51 AM
cooter1's Avatar
cooter1
Default cv axle
why do I need to drain the tranny fluid?
Old Jan 3, 2005 | 10:05 AM
WideBodyEK's Avatar
WideBodyEK
Stage 3 Modified
because tranny fluid will leak out of the hole the axle goes into,...and it probably needs changed anyways
