95 ls thermostat replacement
Old Dec 29, 2004 | 08:57 AM
unique_sa's Avatar
unique_sa
Default 95 ls thermostat replacement
can you tell me how to change the thermostat on this model. i checked out the site team integra but it's for a b18c5 engine, and well i'm not that lucky to have that engine, so can someone tell me how to do this? a manual if that matters. thanx
Old Dec 29, 2004 | 11:20 AM
Provocateur's Avatar
Provocateur
On permanent hiatus
Near the distributor is the thermostat housing. It has a thick coolant hose coming from it. The thermostat housing has two sensors connected to it. The one with a green harness is the ECT sensor and the one with the short skinny black connector is the ECT guage sender sensor. If you can find the housing, you need to remove 3 or so bolts holding it to the head and then you can see the thermostat.
Old Dec 29, 2004 | 11:51 AM
VPUPPY's Avatar
VPUPPY
if you can't find it by the why Shmoo described, follow the lower radiator hose up to the thermostat housing. it curves up around the transmission up to the back of the engine. it starts by the drain plug for the radiator.
