2000 Civic front Bumper
Old Dec 26, 2004 | 09:54 AM
Joker_bliss's Avatar
Joker_bliss
Default 2000 Civic front Bumper
My question is pretty easy. I was wondering how hard it is to replace the front bumper from my 2000 Civic Si. Also I was wondering if this is hard, and if anyone has done it before, how much time does it usually take. What years can I replace it with all I want is a stock to stock switch and can I get it from a sedan or any other civic trim. Thanks a lot for your help.
Old Dec 27, 2004 | 08:43 PM
billscivic00's Avatar
billscivic00
99-00 coupe defiantly, the sedan might fit, probally will since it has the same headlights.
should take about an hour...pop your hood, remove the clips that goto your top grille, take the bolts off each corner near your fender, you will also have to unbolt your splash guard underneith i believe(not sure since i have aftermarket now) it is real easy and you can do it your self.
Old Dec 27, 2004 | 10:25 PM
Joker_bliss
Thanks a lot for your help man. Good i am gona give it a go in a few days.
