too much engine oil or transmission fluid?
Old Dec 16, 2004 | 01:07 PM
vanicult's Avatar
vanicult
Default too much engine oil or transmission fluid?
Hi,
This is a general question.
What happens if you add too much transmission fluid or engine oil?
Does it decrease the efficiency of the engine? Does it induce more wear?
Thanks
Vani
Old Dec 16, 2004 | 04:56 PM
03cbr600f4iguy's Avatar
03cbr600f4iguy
im not an expert, but i think you would blow seals with too much oil.
Old Dec 16, 2004 | 04:57 PM
03cbr600f4iguy
im not an expert, but i think you would blow seals with too much oil. ive always heard that not enough oil is better than too much oil. of course, not enough oil isnt good though.
Old Dec 16, 2004 | 06:41 PM
VPUPPY's Avatar
VPUPPY
may reduce efficiency, does not cause more wear, and will cause your gaskets to go faster. a little bit over the mark on the dip stick will not hurt that much but a lot will. just drain excess if needed
