Cold Cathodes in Car?
Old Dec 5, 2004 | 09:38 AM
fblznolimit's Avatar
fblznolimit
Default Cold Cathodes in Car?
Hey guys, I am curious to chook up a Cold Cathode set that are usually in computers into my car? Is this possible? A Computer systems powersuppply is DC and it pumps 12V right? Can I hook this up to my car without blowing anything up? If i did, where should I connect it to and use what AMP fuse?
Old Dec 7, 2004 | 04:27 PM
LowSky's Avatar
LowSky
dude they make neon tubes for cars made of better materials than the ones you put in your computer... go into any Auto store or any car part site and look them up... companies like streetglow and varad make the stuff and its not too expensive
Old Dec 7, 2004 | 08:02 PM
Nelson's Avatar
Nelson
Administrator
To answer your question, YES they would work and install is as you would any equipment that requires a 12v dc source.
9Y0 Cayenne GTS
E46 ///M3
YD4 MDX
- SOLD
EG Ferio - SOLD
FA Ferio - Returned
www.NelsonLee.net
Old Dec 8, 2004 | 01:25 PM
VPUPPY's Avatar
VPUPPY
you might want to check to see the max voltage on those cuz once the car is running, the cars alternator will increase the voltage to ~14.4.
Old Dec 8, 2004 | 08:41 PM
hype8912's Avatar
hype8912
Dr. Klaw
Voltage on cold cathodes are 12 volts. You can use a voltage regulator or a resistor to control the voltage. The cold cathodes create a great amount of light without the dangers of neons. Also a 12 inch neon will cost around $20 where a dual 12 inch cold cathode kit can cost from $3.99 and up. Average price around $7.99 for a dual kit.
For the hook up, you'll have to be more specific on how you are going to using the lights. I can hook you up with a schematic drawing on how to hook the lights up for what you want them to do.
Old Dec 10, 2004 | 12:23 PM
LowSky's Avatar
LowSky
the problem with cathods is they are made of glass and are meant to be placed inside a computer that will do little moving around.. plus most cathods (and a $4 a tube that sound like the crappy cheap ones) i have played with a very fragile. just get the car made tubes... they are fused and shielded to withstand some abuse
