94 civic radiator flush -- help
Old Nov 30, 2004 | 12:14 AM
darkcyde's Avatar
darkcyde
Default 94 civic radiator flush -- help
just wondering if anyone could help me out and tell me the proper proceedure to flush out my radiator on my 94 civic ex 1.6? thanks in advance!
Old Nov 30, 2004 | 06:11 AM
teg92's Avatar
teg92
WHAT OK YEAH!
there should be a little plastic screw under the readiator just losen that and all your antifreeze will come out. Just take some water pour it down the readiator clean it out. Tighten the plastic screw and put antifreeze in. Thats basically it Good Luck
Old Nov 30, 2004 | 08:11 AM
darkcyde's Avatar
darkcyde
sounds simple enough, hopefully it actually will be! thanks
Old Nov 30, 2004 | 11:51 AM
Provocateur's Avatar
Provocateur
On permanent hiatus
You should run the car with the water in it to flush the crap out of the head and other places the coolant goes.
Old Nov 30, 2004 | 01:16 PM
darkcyde's Avatar
darkcyde
too late, already re-filled it :happysad:
Old Nov 30, 2004 | 01:21 PM
bluetwo's Avatar
bluetwo
Relevance is irrelevant
It should be ok. Watter wetter is supposed to be some pretty good stuff.
Old Dec 3, 2004 | 08:54 PM
TT Tercel's Avatar
TT Tercel
Did you flush the heater core
