Head lights dont come on
Old Oct 6, 2004 | 04:42 PM
southerspeed's Avatar
southerspeed
Default Head lights dont come on
My headlights dont come on but the bright lights still work. i checked the fuses and there does not seem to be a problem. What can the problem be.
Old Oct 8, 2004 | 12:35 AM
kidd_honda's Avatar
kidd_honda
What car, year, model? Maybe the bulb?
Old Oct 8, 2004 | 06:47 AM
saxqtzk's Avatar
saxqtzk
I would double check the fuses and try replacing the bulb... if that doesn't work i'm not sure what it could be.
Old Oct 9, 2004 | 09:45 AM
luky1380's Avatar
luky1380
if you had high voltage bolbs you better check head light bolb conectors the my be burned
Old Oct 25, 2004 | 08:44 PM
canada's Avatar
canada
514.315.407.405
Its the bulb.
Same happened to my car but then it went away after I changed them.
Usually happens to most Canadians in the winter. Everyone is driving around with one working headlight mid-winter cause the cold breaks them somehow too.
Old Nov 13, 2004 | 09:05 AM
oldskoolcivic's Avatar
oldskoolcivic
hey canada, does canada cars just turns the headlights on automatically once its on the ON position or something? everytime i drive to canada, even if its in the summer with sunny days, the canidian cars (canidian license plates) always have their headlights on, but their tailights are not on.
Old Nov 13, 2004 | 04:52 PM
VPUPPY's Avatar
VPUPPY
its called daytime running lights. they have studies that show a reduction in auto accidents as a result of daytime running lights, so i believe most cars in canada, if not all, have this feature.
Old Jan 1, 2005 | 08:27 PM
accordsir86's Avatar
accordsir86
Default Heads dont come on
its probably the switch. if ur gauge lights dont go on as well and ur taillights, then ur combination lights(light switch) switch needs to be replaced.
