electrical problem with A 91 civic - help!!!
Old Sep 22, 2004 | 02:35 AM
EFCivicSi's Avatar
EFCivicSi
Default electrical problem with A 91 civic - help!!!
Hi everyone, I hope someone can help with this. Well, I recently replace the alternator on my car and right after that the signal light, the rmp meter, the fuel meter, clock and the engine heat meter went out. I check all the fuse but they seem to be fine. I check the the wires connecting to the alternator and they seem to be in order and now I don't have a clue where to check next. If someone can give me some info or insight in this I would appriciated. Thank you all for your time.
Old Sep 22, 2004 | 05:12 AM
slate13530's Avatar
slate13530
You should try here :
CRX and Pre '92 Civic you might get more responses.
Old Sep 24, 2004 | 02:12 AM
EFCivicSi's Avatar
EFCivicSi
Thank you
