HELP: identify this acura engine part
Hi all, hope someone can help me out with some info. regarding a name of a gasket/part # and discription. I have an oil leak coming from a cover that is on the front side of the engine, right below the valve cover and right below the spark plugs, in front of the cool fan. It's a flat plate with 8 screws, 4 on top and 4 on the bottom. The plate is about 4 or 5 inches high and 10 to 12 inches in length. What is the name of the replacement gasket part that is needed or part # ? Can i get this from most auto part store.? I ended up ordering the valve cover gasket by mistake. Any advice would be great.
Can you point it out??
Is it an integra?
-PHiZ
