know anything about installing silverstars
Old Aug 6, 2004 | 05:14 PM
stoneswimmer06's Avatar
stoneswimmer06
Default know anything about installing silverstars
looking for help on how to install silverstars on a 92-95 civic hatch, is there any easy ways other than taking off the bumper. If u can help me out at all that would be great. Thanks
Old Aug 6, 2004 | 06:05 PM
saga's Avatar
saga
broke college kid
Aren't silverstars only lightbulbs?
Old Aug 6, 2004 | 07:06 PM
lkailburn's Avatar
lkailburn
college kid
haha you don't have to take the bumper off to change your headlight bulb!
in my 6gen you: unplug headlight bulb plug, remove rubber boot cover, remove retaining wire thing and then remove bulb. install in reverse order
Old Aug 6, 2004 | 09:14 PM
mitsurugi's Avatar
mitsurugi
Super Member
I have a 5th gen civic coupe with silverstars. You definitely don't have to take off the front bumper. You might have to move the power steering resovoir to get to the driver's side bulb easier though. That is all.
Old Aug 6, 2004 | 10:21 PM
saga's Avatar
saga
broke college kid
Yea, that's what I thought. In my 5th gen I replaced the headlight bulbs. Just pop the hood. Look behind the headlight. Pull off the big rubber thing, disconnect the connector for the headlight bulb, pop open the clamp thing that holds the bulb in, and pull out the bulb. Reverse order for install. I also moved the power steering resevoir, it slides right out of it's holder, pretty sure it was designed like that to make it easier. I had a friend help me though cause it was a bitch with the resevoir there.
Old Aug 8, 2004 | 09:08 PM
hoyoung02's Avatar
hoyoung02
HEAT:Shift_TechkaV
simple light-bulb change, it even looks the same as your stock ones.
Old Aug 30, 2004 | 05:53 PM
Art VanDelay's Avatar
Art VanDelay
...Make sure you don't touch the bulbs (the glass part) with your hands prior to installing them! If you do accidentally touch one, clean it with isopropyl alcohol and then install it.
Old Aug 30, 2004 | 10:13 PM
Nelson's Avatar
Nelson
Administrator
It's not that easy if you're a beginner. I remember having my hands scrathed up bad due to the lack of space on the driver side headlight (5gen Civic). Heck, I just installed Silverstar's on the Odyssey, iman it's a pain in the neck to get to the driver side headlight.
9Y0 Cayenne GTS
E46 ///M3
YD4 MDX
- SOLD
EG Ferio - SOLD
FA Ferio - Returned
www.NelsonLee.net
Old Aug 31, 2004 | 07:03 PM
mdaman's Avatar
mdaman
how do you guys like your silverstars? I am thinking of getting some and need some opinions. Plus where did you get them and how much?
