Relocating Ignition
ok guys I need some help here. I am relocating the ignition on my Civic to the dash, and was wondering if the wheel lock pin is in the ignition unit itself? or is it just connected to it. like if I remove the ignition from the column then the wheel won't lock correct...?
now if this is true, is there a way to rig it up so with the key out, the wheel will still lock?
thanks guys, mark
thanks guys, mark
