Compression and leak down test
Old Jul 22, 2004 | 06:38 PM
Vicious's Avatar
Vicious
Default Compression and leak down test
hey does anyone know how i can do a compression and leak down test cause my new car is buring oil. Thanx
Old Jul 23, 2004 | 06:32 AM
JimBlake's Avatar
JimBlake
Get a compression tester, it's like a pressure gauge that goes in the spark plug hole. Warm up the engine completely, take out all 4 spark plugs, pull fuses or whatever to disable fuel & spark. Put the gauge in one plug hole, hold the gas pedal all the way floored, crank the starter until the pressure quits climbing. Then do the other cylinders.
A leakdown test uses a tool that's kinda like a pressure regulator, gauge, & connection for compressed air into a spark plug hole. It'll probably have instructions...
Old Jul 23, 2004 | 11:32 AM
Vicious's Avatar
Vicious
thanx man
