diagnostic and troubleshooting woes.
Old Jul 4, 2004 | 05:25 PM
bluetwo's Avatar
bluetwo
Relevance is irrelevant
Default diagnostic and troubleshooting woes.
I don't know how to diagnose sensors..... I think the speed control sensor may be out.
But the haynes manual doesn't specify if it affects my situation.
I have a dead speedometer, odometer, no cruise control, and no overdrive, (AT). I can't understand why all of these could have gone out at once, and I really don't want to have to pay Honda techs to figure it out. I have a check engine light when I slow to a stop, and no idea why.
Once I blew an ACG fuse, but after I replaced it, no more problems there.
Help......
Old Jul 23, 2004 | 10:43 AM
Human Hybrid's Avatar
Human Hybrid
Take it to like a Midas or some type of shop with a scan tool that diagnose for free...so you can see which sensors and what codes are popping up..
Any problems when you drive?
Old Sep 30, 2004 | 02:56 PM
potato1's Avatar
potato1
its mostly likely your veichel speed sensor, that what was wrong with mine it through a code 17. hope it helps.
Old Oct 1, 2004 | 01:49 PM
Relic1's Avatar
Relic1
Teal Hatch Cult Member
the auto trans has it's own controller. it may be something wrong with that. the VSS and cruise runs though it if I remember right.
For the record... a dead VSS would cause all of those things also.
dead speedometer - no signal
odometer - same drive as speedo
no cruise control - what speed should it set???
no overdrive - how does it know that you're going fast enough to engage it?
what year/type of honda are we talking about here? I may be able to help you though it.
