Cam timing D16Z6 Pully marks
Old Apr 9, 2004 | 06:30 PM
compfreak2002's Avatar
compfreak2002
Default Cam timing D16Z6 Pully marks
I will be parting my motor together soon and there are five notchs on the crank rod pully, one with a red mark, I know they mark top dead center, can I set my cam timing to one of the different marks?? Will it effect the top end power low end power or bend valves??? Which notch should i use to set the cam timing and which should I use to set the ignition timing???
Old Apr 11, 2004 | 10:19 AM
compfreak2002
seems when people get technical with hondas in here nobody knows what the hell is going on
Old Apr 13, 2004 | 01:03 PM
Civic2Scooby's Avatar
Civic2Scooby
the different marks indicated retarded or advanced timing....retarding the timing is usually done to prevent detonation aka for turbo, nitrous etc. you can slightly advance your timing if you like to give you a very little more throttle response.
Old Apr 13, 2004 | 01:22 PM
compfreak2002
Which one is for the Cam timing?? Can I advance or retard the valve timing also?? Which timing mark should i use to set my cam gear?
onthekeyboard
CRX & Pre 92 Civic
20
Aug 12, 2003 02:23 PM
DanM
Engine Swaps, Tech & Tuning
12
May 7, 2003 07:22 AM
VtecApprentice
20
Nov 30, 2002 08:02 PM
