Integra Instrument Panel Bulb Replacement
Old Mar 11, 2004 | 03:25 PM
NephilimSurfer's Avatar
NephilimSurfer
Default Integra Instrument Panel Bulb Replacement
I think that one of the bulbs is out on my 94 Integra. The left side of the instrument panel doesn't light up. All the warning lights come on fine when the car starts and I checked all the fuses. Its not a big deal, I just can read the temperature gauge at night.
From what I understand, there are three bulbs behind the panel. For those of you who have taken apart the panel before, are there any things that I need to be aware of that would make the replacement easier? Do I have to do anything to disable the SRS system while I'm working on the panel?
I haven't gone to the dealer to get the bulb yet. I'm assuming that it shouldn't be too expensive, so I'll probably replace all of them while I have the panel open.
Old Mar 13, 2004 | 03:24 PM
b00gers's Avatar
b00gers
it uses a wedge bulb. i forgot the number, but im thinking 192? not quote me on that.
you dont have to disable anything. but if you are concerned, take the negative cable off the battery, since you are going to be unplugging harnesses...but its not too much of a worry.
there are two screws that are on top that you will remove. that will take the black trim area out. then looks for the screws that are holding in the gauges itself. shouldnt be more than 5-6. then unplug the 3 harnesses. and you should see the bulbs from the back. simply unscrew and replace. then work backwards from there.
i know there are images around floating on the net.
Old Mar 15, 2004 | 10:49 AM
DRAG 3 INTEGRA's Avatar
DRAG 3 INTEGRA
Drag # Integra
194 wedge.. come in all kinda colors, i replaced mine with ambers one
DownLowAcc
Accord
May 11, 2003 10:19 AM
pregunta
5
Apr 23, 2003 05:03 AM
SHAUNTS99
6
Mar 3, 2003 05:08 PM
SH_Mon
Prelude
3
Jan 24, 2003 10:13 AM
