civic door panel removal 92-95
Old Feb 25, 2004 | 11:08 AM
dookieface's Avatar
dookieface
Default civic door panel removal 92-95
How do you remove the door panal for a rear door panel power window. How do you take off the door handle/switch panel? I'm trying to install a new window
Old Feb 26, 2004 | 03:42 AM
Wharbone's Avatar
Wharbone
Shere is a screw in the handle, a screw in the little coin pocket thing, and a plastic screw near the mirror.
After you take thes out, disconnect the handle linkage.
Now take a fat screw diver and pry the panels off. There are several several plastic clips that hold the door on all around the outside of the panel. Put the screw driver as close to the plastic clips as you can to avoid damage.
Now disconnect the electrical plug to the windows if you have power windows. The panel should now be free.
It's really easy. You shouldn't have a problem with it.
egjoe
Nov 11, 2004 04:16 PM
Daniel
News & Rumors Archives
17
Sep 6, 2003 06:20 AM
jaje
19
Mar 26, 2003 03:58 PM
hyperlite
Engine Swaps, Tech & Tuning
7
Jan 29, 2003 08:19 PM
jaje
17
Jun 27, 2002 03:16 AM
