Help: Goodridge Lines Installed (Pics)
Old Feb 4, 2004 | 07:16 PM
h22avid's Avatar
h22avid
Sleeper...Creeper...
Default Help: Goodridge Lines Installed (Pics)
Ok, kind of a stupid question but I was wondering if anyone had pics of their goodridge lines installed (mainly on the front).
I don't need to know necessarily how to install them, I've already done that. I'm more concerned with where the slack should be and where to place that semi-clear rubber sleeve on the fronts.
The goodridge lines have those free floating brackets and this 1 inch rubber sleeve that hugs the line pretty snug. I just want to make sure I got the slack in the right spots so theres no tension on the lines as the suspension moves through its range of motion. Also should the rubber sleeve be slid against one of the brackets to keep the line from slipping back and forth through the bracket or should it be placed somewhere on the line to keep it from rubbing or wearing on something?
Old Feb 6, 2004 | 11:02 AM
Hondaaccordvtec's Avatar
Hondaaccordvtec
With your front tires off, just have someone move the steering wheel from lock to lock and watch the brake hoses for any binding.
Old Feb 6, 2004 | 03:58 PM
h22avid's Avatar
h22avid
I'm not so much worried about the spindles turning but rather when they move up and down as the car travels through its range of motion with the suspension.
Anyhow I think I'm good now just wanted to get some input... Thanks
Old Feb 6, 2004 | 04:11 PM
h22avid's Avatar
h22avid
OK someone posted a logical answer to this same question that I posted on some other boards... anyhow here's the response I got... I read it and was like :doh: :cheers:
http://www.superhonda.com/forum/show...57#post1480157
h22avid
92+ Civic/EL & Del Sol
7
Feb 6, 2004 04:12 PM
96Vtec
Accord
19
Jun 30, 2003 10:12 AM
ambition
Mar 20, 2003 10:26 AM
AznDarkMagician
33
Feb 12, 2003 11:06 PM
