Where's the thermostat on a 91 Integra?
As the subject says, I'm looking to replace the thermostat. I'd like to know it's location so I can get to it.
Temp guage stays low. No heat from vents. Everything seems normal. Coolant is good, there are not leaks and it's topped up.
Help would be appreciated.
k.
k.
Rotorphile.
Follow the top radiator hose back to the block. You will see that the large bung it attaches to is bolted to the engine. Pop off the hose and unbolt that housing, and you'll be looking right at it.
