window tinting
Old Dec 24, 2003 | 05:52 PM
menappi's Avatar
menappi
Default window tinting
have any of you attempted to tint your windows your self? i tried one time in my crx, and had a hard time getting the bubbles out, came out alright, but lost of little bubbles, it hink i used too much water. any how to's or tips? also, how do you do it when one sheet isnt wide enough, or for curved glass?
Old Dec 25, 2003 | 06:41 PM
habitatsk8r392's Avatar
habitatsk8r392
Certified Ricer
here's a tip: take it to a tint shop.
ur a fool if u do otherwise un less u have some serious h4x skill...if you do it yourself if will look like you did it yourself.
Old Dec 26, 2003 | 01:58 AM
itechengineers's Avatar
itechengineers
PC's_N_CaR_EnGiNEeRiNGMaN
Default tints tints
hey I got a little exp...... $|-|iT lods of soapy spray soloution or window washer fluid..... gallons already prep'd in spray bottles... when the tints are wet with the soapy soloution, it moves! constant spraying and slicing of your tool kit with patience....... At one time I actually moved an entire peice as a demonstration aim at a friend (it slid right off the glass).... if its wet you can work with it... but hell wet it again, it'll be easier on you, patience but work fast! try it gluck! practice.... and dont forget about the individulas interror, you dont want to drown their rugs :-}!!!
Old Dec 27, 2003 | 08:43 AM
PreDude1's Avatar
PreDude1
"Local Neighborhood Pimp"
Heres a tip from a expierience window tinter.. first off all u have to be REAL patient.. patience is the key to anything.. u dont wanna rush.. secound dont use alot of soap water.. but do make ur water sopy.. use alot of soap.. make sure u have a nice little squigi (cant spell) try not to use the cheap plastice ones u need a nice rubberish one.. also use a hair blow dryer to dry up those annoying bubbles.. (CAREFULLY).. that why u must use the right amount of soap water... less water less bubbles.. hope it helps.. PS. CLEAN ur window DAMN! good.. use a nice blade to sorta scrape ur window clean.. cuase lil dust particles can create nasty bubbles..kinda like u take off a old city sticker.. same idea. except ur cleaning ur window.. hope it helps..
