some quick Q's
Old Dec 15, 2003 | 12:39 AM
Mr.Badguy's Avatar
Mr.Badguy
Default some quick Q's
Whats the best way to put mesh on a front bumper?
Whats the best way to mount foglights?
whats the best way to patch up chips in fiberglass?
Old Dec 15, 2003 | 05:00 PM
firebane's Avatar
firebane
chips in fibreglass you mean in the sense of like rock chips and dings and such? The easiest way to fix those is with bondo :P Or the other thing you could do that I've done a few times is rough up the area around it like you'd fix one on a car and fill it with resin, but you gotta make sure its really rough even the inside of the hole so the resin can hold. But this isn't the best fix, most people I know just used bondo.
Old Dec 19, 2003 | 03:51 PM
DSMtuner's Avatar
DSMtuner
(-_-)/'i')
mesh - small screws
foglights - varies on every car. On my friends nissan, there were two unused bolts in perfect mounting positions, so we used those and didnt have to drill a thing. On others, you will.
id say bondo too on the chips. Easy and effective
Old Dec 21, 2003 | 06:54 PM
Nightshade's Avatar
Nightshade
un-Touch'd krew
Default Re: some quick Q's
For mesh I use zipties or you can also use hotglue if you have it available and it will hold up.
Foglights it depends on where you are mounting them and on what bumper as well as the size of the light. I have a small set I installed on mine and I predrilled holes just big enough to put the screw through then used a backing plate to tap the screw through and it has held up fine for me.
Chips or holes in fiberglass? If its just little chips lie paint chips then sand it prime it and paint it.
If its holes, punctures, or tears then you would be best off getting some kitty hair and filling it from the backside then sand prep and paint.
Old Dec 27, 2003 | 09:04 AM
Civic2Scooby's Avatar
Civic2Scooby
rivets own you for mesh in the grill..
