88 honda hatch axle removal
Old Dec 3, 2003 | 09:55 AM
88hondahatch's Avatar
88hondahatch
Default 88 honda hatch axle removal
how do i remove the front axles in my 88 honda hatch????? please help
Old Dec 5, 2003 | 10:12 PM
tylercrx's Avatar
tylercrx
i need to do this too, and before i mess anything up id like some advice. mine is for the driver side axle, the bolt is huge, i think its 32 mm. but any advice? thanks.
Old Dec 5, 2003 | 10:19 PM
88hondahatch
Default Just took out my axles**
Man its way easy just disconnect all the ball joints the foork the bar thats attahced to the fron of the car and the caliper then you just pull it out. I would recomend pulling off the spindle nut first cause its a bitch i got to go have mine taken off by a shop cause its on so tight.:madfawk: :thumbup:
Old Dec 9, 2003 | 12:10 PM
honda1998civic's Avatar
honda1998civic
do you pull control arm off ball joint or do you just unscrew nut?
Old Dec 22, 2003 | 04:59 PM
menappi's Avatar
menappi
when the carson the ground, undo the spindle nut. just take a 32 mm i believe socket and a long ass breaker bar. then undo the castle nut on the bottom of the knuckle, take the brake pads off, and pull everythign to the side, and slide the axel out.
Old Jan 8, 2004 | 08:13 PM
1995 B16A's Avatar
1995 B16A
Just took off my drivers side axle on my 95 honda civic B16a2 swap...
Lose spindle nut of course, remove lower control arm and then the fork..... no need to remove any of the brake system as far as I know... Didn't have to on mine... Then, if you have a half shaft, remove where the CV joint connects to the half shaft, remove axle... Reverse to re-install.... Make sure axle pops onto half shaft....
If you have half shafts, there will be no need to drain tranny fluid, but will have to on passenger side...
