2002 Accord -- Reading SRS Codes
Old Oct 15, 2013 | 02:37 PM
boxer's Avatar
boxer
Default 2002 Accord -- Reading SRS Codes
I have a 2002 Accord (2 door, SE). I believe that makes it 6th generation.
The SRS light has recently come on and won't go off. I want to pull the code(s) using the method I've read in several places -- short the diagnostic connector using a wire or paper clip and read the flashes/blinks. However, I'm confused because I've found contradictory instructions:
In some places it says to short pins 4 and 9. In other places it says to short pins 8 & 13. They also all caution you not to short the wrong pins. So, which are the correct ones? Obviously I want to be absolutely sure!
Thanks in advance for your help.
MrChad
Accord
16
Feb 4, 2005 02:27 PM
procircuitcr
4
Aug 3, 2004 08:24 AM
MokeyJ
Accord
6
Nov 10, 2002 03:59 PM
