can i get a how to on polishing a valve cover
Old Nov 14, 2003 | 06:10 PM
RY2K's Avatar
RY2K
5 speed
Default can i get a how to on polishing a valve cover
i know i need to start with a rough sand paper then work to like 2000 grit or something like that
and do i need to wet sand it
thanks
-RY
Old Nov 15, 2003 | 12:22 PM
dom93hatch's Avatar
dom93hatch
more meat, more fire
PM member jaymar88. I believe he spent a whole day polishing his valve cover...lol. I think you have to strip the paint first before hitting the sandpaper. Get a can of aircraft paint stripper and remove the paint first.
Old Nov 15, 2003 | 03:55 PM
RY2K's Avatar
RY2K
5 speed
ok
thanks
Old Nov 16, 2003 | 06:19 PM
rlstump18's Avatar
rlstump18
From: Syracuse New York + Hershey Pennsylvania (dependin
once you get an answer post it here...i'd be interrested in hearing how to
Old Nov 17, 2003 | 05:07 PM
XxJBazarnikxX's Avatar
XxJBazarnikxX
Hey I'm interested also....Also can anyone post pics of a valve cover thats done in the same process im not talking about the polished valve covers you buy.....I'm talking about those who done it themselves.
Also what about the rust problems, what have you guys done?
Old Nov 18, 2003 | 11:15 PM
WideBodyEK's Avatar
WideBodyEK
Stage 3 Modified
aircraft stripper is what you are gonna need to get the black shit off the valve cover at first,..spray the aircraft stripper on there and let it sit for like 15 mins to eat away at the black shit,..do this until all the shit is completely off the valve cover,.until you have it down to bare metal,...now i apologize that i dont know the specific grits of sandpapers because i did this a long time ago,..but you do start with a rougher grit,..and then gradually the grit gets finer,..and yes you do wetsand,...after you have sanded the bastard down till it starts to somewhat shine,..you will need a polishing agent to get it to somewhat "bling",..i used eagle one polishing,...just a warning though,..after finishing the valve cover,..you will hate sanding forevAr :chuckles: ,...i was pretty much day long process for my valve cover
Old Nov 23, 2003 | 11:56 AM
cstem's Avatar
cstem
If you have access to a air compressor: Remove the paint by stripper or sandblasting with a light media. Get a die grinder and some polishing wheels and start to polish lightly. Be careful here as you can remocve metal and create uneven surface. Polich out by hand or with an orbital sander with a polishing pad. Much faster than by hand but be careful.
Old Jan 17, 2004 | 07:33 AM
1995 B16A's Avatar
1995 B16A
Does anyone know how to strip the surface of a B series factory powder coated valve cover??? Is there any real way to do it???
Old Feb 6, 2004 | 07:32 AM
sa863c's Avatar
sa863c
I have done a couple of valve covers for myself as well as friends, I use a light media in the blast cabinet, then different types of polishing compounds, I start w/ the black stuff, then brown and finally white, took me all day, but it looks good.
if you don't mind spending $$, it is about a hundred and fifty bucks to have it chromed..
And for those of you that have powder coated covers, try the stripeeze from your local home depot, it worked for me, just soaked the valve cover in the crap for about 3 hours...paint peeled right off, but beware of the fumes...
Old Apr 1, 2004 | 05:53 PM
H22accordR's Avatar
H22accordR
H22accordr
Default Polishing a Intake Manifold
I was wondering if using the same process would work or even be a good idea on a intake manifold (the thing that says PGM-FI on my 91 Accord) after removing it. it is discolored and that would do ALOT to enhance to look of my motor. Or even advice to bring back the original bright silver color.
