can i get a how to on polishing a valve cover
Old Apr 1, 2004 | 06:35 PM
sa863c's Avatar
sa863c
Originally Posted by H22accordR
I was wondering if using the same process would work or even be a good idea on a intake manifold (the thing that says PGM-FI on my 91 Accord) after removing it. it is discolored and that would do ALOT to enhance to look of my motor. Or even advice to bring back the original bright silver color.
Yeah, you can sand it down with different grit sand papers until you get it smooth, then start in w/ the different polishes, black, brown, then white....good luck, it is going to take ya a while...
