Leatherique
on a semi-related note one of my "friends" sat down in my leather clad miata with a screwdriver in his back pocket. It didnt tear the seat so much as make little flaps down one side, more like a scrape. What's the best way to hide this? Any ideas?
Originally Posted by b00gers
This looks like something I am going to need.
If I get the Rejuvenator Oil, will the Prestine be required also.
I have a 99 Integra Sedan, about how many applications can I expect from a 16oz bottle?
When you goto the Rejuvenator Oil it is important that you have the Prestine Clean step because you are actually removing the Rejuvenator Oil with the Prestine Clean product. Otherwise you'll have a big mess and the leather will not come out the way you want it to.
16oz bottles will last you anywhere from 2 - 4 applications with the Rejuvenator Oil. It really depends on how much product you are using. I think Leatherique actually suggest 4oz per seat which IMO is way overkill.
Prestine Clean will last you more applications but you typically will run out of that faster as you will use that more often than the Rejuvenator Oil. I'd suggest Rejuvenator Oil once or twice a year with the full process as Nelson described.
Hope this helps, if you need a hand putting together a package please do not hesitate to PM me with any questions.
Sincerely,
George @ Detailed Image
Let me know if there is anything else I can help you with.
Originally Posted by Detailed Image
First of all, I'd like to thank Nelson for the nice write up on his Leatherique experience. It is a lenghty process but usually worth the time and money when you are finished.
Sincerely,
Sincerely,
I say once a year with the full oil is fine, of course more often if you drive more.
At first, I just sprayed the cleaner to wipe off the oil. It was still quite a 'mess'. I followed up with a damp microfiber towel and then finally with a dry microfiber.
Well worth the time and effort. I would have to say anyone with leather interior should get these two products.
9Y0 Cayenne GTS
E46 ///M3
YD4 MDX - SOLD
EG Ferio - SOLD
FA Ferio - Returned
www.NelsonLee.net
9Y0 Cayenne GTS
E46 ///M3
YD4 MDX - SOLD
EG Ferio - SOLD
FA Ferio - Returned
www.NelsonLee.net
