HELP! CRX Backfiring!
Old Oct 7, 2003 | 09:03 AM
scriz's Avatar
scriz
B18 powah!
Default HELP! CRX Backfiring!
Hello all, I was driving down a hill this morning and all of a sudden my car dies while i'm going 85-90, well I try to start it again while coasting to no avail..i coast to a stop and get it started but it died again with alot of backfire, its an 88 CRX 5spd 158,xxx all stock..anyone give me any insight on what it could be?
Scriz
88 CRX
Old Oct 7, 2003 | 09:10 AM
95civicEX_h22's Avatar
95civicEX_h22
Slo N Low
Timing?
Bird in intake box?
Air, Fuel, Spark
If it starts then cuts off could be clogged something, intake - fuel filter or fuel pump starting to go bad - bad wires, plugs, or distributor.
May sound stupid but i dunno... is the coil separate from the distributor? Could be coil or coil wire.
Is it throttle body injected or carborated?
Has it started to smoke recently? (clogged pcv valve)
You wanna sell it?
Old Oct 7, 2003 | 09:27 AM
scriz's Avatar
scriz
B18 powah!
its injected, no it hasn't smoked at all, i was going to trade it for a 94 Probe GT lol, unless I fix it I won't be trading it
But, would it being clogged anywhere cause it to backfire? I've drove a car with the fuel pump about to go out and it didn't backfire at all, just cut off every now and then..i dunno just looking for some suggestions on what to check
Old Oct 7, 2003 | 09:53 PM
Gasoline Fumes's Avatar
Gasoline Fumes
Automotive Enthusiast
I would pull off the distributor cap and check the condition of the cap and rotor. Make sure it's clean and dry in there and/or just replace the car and rotor.
Old Oct 8, 2003 | 08:11 AM
scriz's Avatar
scriz
B18 powah!
Uncle came over today, had me crank it and it sounds timing related I say, he agrees, take off the valve cover and the timing cover, belt is still in tact, gears look decent..and it is firing, just sounds like the timing is WAY off, My uncle says that he thinks the tensioner is broken..anyone know how much a tensioner would be?
Old Oct 8, 2003 | 08:12 PM
Mx6GT91's Avatar
Mx6GT91
:thumbup: Damn straight, with the 2.5L V6 hope its 5speed
If its got low miles on it then go for that, must be 5speed though. The automatics have some problems
Old Oct 9, 2003 | 07:17 AM
jlicrx's Avatar
jlicrx
sounds like your timing belt jumped several teeth
Old Oct 9, 2003 | 09:50 AM
LSVTECKING's Avatar
LSVTECKING
rebuilding
I'll almost guarantee its a distributor problem. But check your timing anyway.
Old Oct 9, 2003 | 12:03 PM
scriz's Avatar
scriz
B18 powah!
Default timing tensioner
well, my uncles thinks its the timing tensioner, we went to pull off the harmonic balancer to get to it and guess what..we called the honda dealer and the harmonic balancer bolt calls for almost 1000ft lbs of torque
anyone know any way around that? because we have to rent an air compressor and a 3/4 air gun, ugh!#@$
Old Oct 9, 2003 | 12:06 PM
scriz's Avatar
scriz
B18 powah!
yeah..so i hear..its an auto..but the tranny was rebuilt about 60k miles ago and he has reciepts for it and its not for me its for my girl..i have a 95 Beretta Z26 that I'm doing a gasket job on
