what do i need for spraco seats?
if the rails arent compatable with the floor u can always drill right thru the floor, which is done with most cars when changing seat rails out... just to let u know
Z20 H8R
if you drill your floor it can have after effects later down the line. i did this for my del slo seats into the crx. the combination of a full grown mans weight and the b16..cause my drilled holes to stretch out. this caused the bolts to becoem stripped. this happend because the metal that you drill through in the bottom of the floor wasnt designed to bare this load. the stock mounts have reinforced metal all around the screw holes so this wont happen. solution to my problem? i took it back to the guys who installed these seats, i had them weld on some tabs to the rails and use the stock bolt up spots. problem solved. shoulda been done like that the first time.
