Blower Motor Question
Old Sep 3, 2003 | 08:18 PM
Scrub91DX's Avatar
Scrub91DX
Un-Registered User
Default Blower Motor Question
when i turn on the heater or a/c i can hear the blower kick in and run, but it hardly blows any air out, on the highest setting it isent even enough to warm the car up in the morning, or cool it off with the a/c on. anyone have any idea what could be causing it not to blow much air out?
-Matt-
Old Sep 4, 2003 | 05:21 PM
LSVTECKING's Avatar
LSVTECKING
rebuilding
The shaft of the blower motor probably stipped the teeth on the finned section itself, so the motor is spinning the shaft only.
Old Sep 4, 2003 | 06:10 PM
Redlinerz's Avatar
Redlinerz
This prolly isn't it but just in case before you go buy a new moter...check under you steering colum and make sure the plastic tubes for the air are connected all the way and are there.
Old Sep 8, 2003 | 12:36 AM
hondatech's Avatar
hondatech
Honda tech/eprom hackr
it sounds like your blower resistor is bad. that or the blower motor itself. I had a resistor pack go out in a 95 civic once that I soldered back together and it worked great again.
Old Sep 8, 2003 | 03:35 AM
FourthGenHatch's Avatar
FourthGenHatch
I'm RICK JAMES, bitch!
Make sure your coolant system is full. Turn the heater to 4 and turn on the car. Take off the radiator cap and see if it is full. Also make sure your reservoir is full to.
Old Sep 9, 2003 | 09:59 PM
hondatech's Avatar
hondatech
fouth gen hatch he's talking about the blower fan in the car not in the engine compartment.
