Sohc V-tec
Old Sep 2, 2003 | 10:45 PM
Redlinerz's Avatar
Redlinerz
Default Sohc V-tec
I got a question. I got a 1993 1.5 V-TEC and am putting it in a 1990 civic. the 90 was DPFI so I put on a 88-91 manifold and converted my dx harness. My question is can I use the 93 Distributor or do I have to get me a 88-91 SI distributor? Thanks
Old Sep 2, 2003 | 11:03 PM
Kai's Avatar
Kai
Rotorphile.
88-91 Si distributor. It doesn't bolt up exactly, you have to play with it a bit. Only two of the three bolts will align, IIRC.
Old Sep 3, 2003 | 09:29 AM
Redlinerz's Avatar
Redlinerz
But can I use the 93 distributor??? OR it won't work and I HAVE to use a 88-91 SI one?
Old Sep 3, 2003 | 09:31 AM
Kai's Avatar
Kai
Rotorphile.
Use the OBD-0 Si distributor unless you plan to use the OBD-1 P28 ECU. More conversion work would be needed to run a P28.
You have to use the Si distributor if you keep your Si ECU.
Old Sep 3, 2003 | 05:52 PM
Redlinerz's Avatar
Redlinerz
Okay that is what I was thinking. Because I am using the 93 distributor and my car isn't starting and I was thinking maybe it is bacause that dist. is for a OBD1 ecu and mines is OBD0. You think thats it?
Old Sep 3, 2003 | 06:46 PM
Kai's Avatar
Kai
Rotorphile.
Yeah, that would cause some problems.
What are you using for VTEC activation? An RPM switch?
Old Sep 3, 2003 | 07:21 PM
FourthGenHatch's Avatar
FourthGenHatch
I'm RICK JAMES, bitch!
VTEC.
Old Sep 3, 2003 | 09:19 PM
Redlinerz's Avatar
Redlinerz
I haven't hook up the v-tec to anything yet. I am waiting for the car to turn on first then I plan on buying a RPM switch. Have you ever heard of someone succesfully doing this swap? And if so with the 92-95 dist and leaving there car OBD-0. I think this is what is causing me problems and am probably going to switch to a 88-91 dist. But if has been done before succesfully then there is something else that is not letting my car start. let me know
