realtime 4wd
Old Jul 14, 2002 | 01:19 PM
excitid's Avatar
excitid
Default realtime 4wd
How exactly does this transfer of power work. I understand the slippage of the front wheels factors into the transfer but whats the percentage and what mechanical funtions take place. Will the 4wd drive only work with the 6 speed trans. last question is does this system share anything other then its name with the crv
Old Jul 14, 2002 | 02:45 PM
jaje's Avatar
jaje
HC Racer H5
the cr-v is an all wheel drive system meaning it powers the fronts until the rears slip...this gives it better fuel mileage instead of losing gas powering the rear wheels when un-needed...you can search around the web or go to the honda dealer and read a brochure on how the cr-v's awd system worked
the civic 4wd was that...all time 4wd which hurts gas mileage...only the 6spd tranny worked with the 4wd system
Old Jul 14, 2002 | 05:24 PM
Gasoline Fumes's Avatar
Gasoline Fumes
Automotive Enthusiast
I think the power for the rear wheels comes off of the front differential. On the Civic Wagons there is a viscous coupling on the drive shaft that allows the front wheels to power the car normally until they begin to lose traction. When there is a difference in speed (about 3%) between the front and rear axles, the viscous coupling will send power to the rear wheels. The CRV has a more complicated system that I've heard doesn't work any better.
123
Minivan, SUV, & Truck
10
May 1, 2003 01:14 PM
loodboi
92+ Civic/EL & Del Sol
19
Feb 20, 2003 10:14 PM
VtecApprentice
Track & Autocross
3
Jan 29, 2003 10:45 AM
Legend_master
CRX & Pre 92 Civic
11
Nov 6, 2002 04:16 AM
yohbee
Oct 28, 2002 12:25 PM
