d16 into a 90 dx?
i've got a 90 crx si with a bent(destroyed) frame. i have a chance to get my hands on a 90 dx. if i do then i'll throw in my d16. what'll i need to complete this swap? what more info can i give anyone out there in han land to find out what i need, or know if i'll already have what i need. thanx in advance.
Originally posted by AwwsChwA
everything will swap over. Take out the engine, tranny, ECU and complete engine wiring harness, and put it in your DX. Voila, an Si in disguise
NO NO don't go and start splicing wires. If you have the whole si just take EVERYTHING OUT. jlicrx is right the harness will not clip in..but since you got the whole si just look underneath the dash and there you will see the harness that goes to the ecu and just take that out and transfer over to the dx and voila ur done. this is the easist way trust me.
Originally posted by Caster Troy SI
so just take every thing that is good(the body is f**ked and bent all up) and put it in the dx and i should be fine is what your saying?
lol....everything??? They all have clips..you bareley have to take the dash apart. Caster troy listen the whole interior harness is not connected. Just look under you dash and you will see the wires to the ecu..follow them back. Just start ripping them kickpanels out and follow the wires, they go straight into your engine bay..that's all you need. The wires that go back to the lights and shit like that you don't need that just clips on. Now the wires that go to the front headlights..them you do need but it is all connected. Just take your time and you will be fine. This is the easiest way and gives you car a much more cleaner look.
