B16 Axles 90 crx SI
B16 Axles 90 crx SI
Hello. At our shop we are doing a b-16 swap into a 90 crx SI. The b16 has the y1 tranny and intermediate shaft. I heard somewhere that you need to use a 90-93 integra shaft with the crx outer cv joint. This did not work because the crx outer cvjoint would not fit on the integra shaft. I have also found the complete axle kit on raxles.com. What would i have to use to build the correct axles for this car. If we cant find anything we are gonna have to pay $329.95 plus shipping from raxles. T hanks alot.
Jayson
Jayson
Rotorphile.
HAsport used to have the info on their site, but it looks like they just deleted it when they started making their own prebuilt units.
If I recall correctly, you can use 90-93 Integra axles after you modify the outer CV joint... some little thingie you pull off so it will seat deeper. Unmodified, they are too long.
If you could find SiR axles and intermediate shaft that would be ideal.
