people with St sways and after market exhaust
ok if u saw my one post from a while back with all my problems
hood vibration (fixed with those rubber gromet things)
brakes ( fixed worn down pads in rear with new pads n rotors
bumper vibration (not fixed)
bumper vibration (not fixed) <------ i came to the conclusion today when fixing my brakes that the one hanger for my exhaust is rubbing the metal n bushing on my rear sway bar causing a loud vibration noise.....
i was thinking of getting some dyamat shit that people use for sytems rattle n putting it on the hanger of my exhaust...
idk if this will work, or if nayone welse has any tips on this, but i need some dyamat to test this idea out...
) bumper vibration (not fixed)
on my lower rear tie i had the same problem. what i did though is took the bolt that hangs my canister and moved it up to a bolt that was about 1 inch closer to the bumper, creating a small 1 inch gap between the bar the pipe leading to my canister. i had it on the lift when i did that though so you might have to do that or at least crawl or wheel around on a creeper.
