1.5 L distributor Question
Old Jul 3, 2003 | 04:47 PM
89waggy's Avatar
89waggy
Default 1.5 L distributor Question
Background: i am working on a 89 wagon for a friend, its not sparking
i have traced to problem to the distributor shaft ( the one that the rotor attaches to) is not turning at all i dont know about this engine at all. Is it gear driven from the exterior of the engine or does the shaft run into the engine? I'm going to buy a used distributor from a junkyard, what i need to know is could it have torn up a cam gear or something else that i will need to replace?
thanks
Old Jul 3, 2003 | 05:33 PM
jung4g's Avatar
jung4g
Asianalize your car
The distributor is connected with offset tabs to the cam, if it's not spinning, it's probably a broken distributor. I'll sell you one for $40 shipped, otherwise good luck...
jung
Old Jul 3, 2003 | 05:39 PM
FourthGenHatch's Avatar
FourthGenHatch
I'm RICK JAMES, bitch!
I just sold my DX Dist on eBay for $50 so Jung is giving you a deal on that.
Old Jul 3, 2003 | 09:54 PM
wagon89's Avatar
wagon89
Are you sure the timing belt has not snapped? If the cam is not turn niether is the dist. I would pull the cover off I make sure. Dist just don't stop turning and I have yet to see one broken on the flange drives.
Old Jul 6, 2003 | 10:57 PM
89waggy's Avatar
89waggy
if the timing belt broke, if the valvetrain most likely trashed or is this a non-clearance engine?
Old Jul 7, 2003 | 12:05 AM
wagon89's Avatar
wagon89
If the belt broke the valves are going to be bent. On the plus side if the car has rear speaker pods in blue I will be them this should offset some of the cost of repairs
