**FourthGenHatch**
Old Jul 1, 2003 | 02:32 PM
91_Hulk_Si's Avatar
91_Hulk_Si
M0der@t0r Assassin
Default **FourthGenHatch**
I checked out your page... Very Nice...
My engine is at 196500 miles and beginning to blow the old white smoke. I saw your ZC sawp and I'm very interested. What is the actual engine serial number or D series number of the ZC motor. I already have an si so i won't need to change trans, throttle cable, mpfi parts, or axels??? Does the a/c bolt right up to the ZC motor or do i need to find a ZC a/c unit. And can you tell me the year of the vehicle and model that that ZC motor comes stock in so I can start hunting one down? Thanx
Old Jul 1, 2003 | 02:40 PM
Snoopy's Avatar
Snoopy
been there done that
learn to use PM
Old Jul 1, 2003 | 03:07 PM
FourthGenHatch's Avatar
FourthGenHatch
I'm RICK JAMES, bitch!
ZC engines just say ZC on the block...
A/C bolts up
DOHC ZCs came from Japanese model Civic/CRX Sis.
Old Jul 1, 2003 | 03:21 PM
crxb16er's Avatar
crxb16er
yeppers ud just need a zc long block assembly to attach to ur si tranny, be newhere from 300-500 bucks depending on ur area.
Old Jul 1, 2003 | 04:00 PM
91_Hulk_Si's Avatar
91_Hulk_Si
M0der@t0r Assassin
exhaust manifold?
Distributor and plugs?
belts?
Intake Manifold?
Old Jul 1, 2003 | 05:31 PM
FourthGenHatch
Originally posted by 91_Hulk_Si
exhaust manifold?
belts?
Intake Manifold?
Exhaust manifold from the 88-91 Civic works.
Distributor and plugs are '89 Integra
Belts, timing is '88 Prelude 2.0 Si and the rest should be 88-91 Civic Si
Intake Manifold, I believe the ZC intake manifold is unique, or so I've heard. If not probably 89 Integra.
Old Jul 1, 2003 | 05:39 PM
91_Hulk_Si's Avatar
91_Hulk_Si
M0der@t0r Assassin
And what year/model integra did these come in?
Old Jul 1, 2003 | 05:54 PM
FourthGenHatch
They never came in an Integra. 88-89 Integras had D16A1s which were similar but by no means the same, and an Integra engine WILL NOT bolt into your 4G Civic.
Old Jul 1, 2003 | 06:05 PM
91_Hulk_Si's Avatar
91_Hulk_Si
M0der@t0r Assassin
So what did these come in? Or was it stricky Japan Stock. The Integra does have the 1.6L DOHC that looks just like the ZC but its not?
Old Jul 1, 2003 | 06:07 PM
FourthGenHatch
They came in Japanese Civic/CRX Sis, they came in a couple of European Civics/CRX not sure of the name but they call those D16A8/9 not ZC I don't think.
