altenator bolt
Old Jun 26, 2003 | 08:34 PM
Maverick37's Avatar
Maverick37
The Perfect Drug
Default altenator bolt
so I went to tighten my altenator belt the other day cause it was slipping. when I am about to tighten it I realize the bottom bolt that holds the altenator in place is gone. where can I find a new bolt? what places carry them? thanks for your help
Old Jun 26, 2003 | 09:31 PM
FourthGenHatch's Avatar
FourthGenHatch
I'm RICK JAMES, bitch!
http://www.hondaautomotiveparts.com/...L5MT&catcgry5=
Somewhere on there should have it.
Old Jun 26, 2003 | 10:41 PM
matt j's Avatar
matt j
midwest corn killer
either what fourthgen hatch said or you can do a junkyard run and you might get lucky
Old Jun 27, 2003 | 02:10 AM
Kai's Avatar
Kai
Rotorphile.
I'd get one from a junkyard. They usually give little crap like that away for free.
Old Jun 28, 2003 | 07:58 AM
crxb16er's Avatar
crxb16er
they sell those longer metric bolts at pepboys if u want an even simpler choice. same with starter bolts.
Old Jun 28, 2003 | 09:30 AM
FourthGenHatch
The alternator bolt has a square side on it that locks against the bracket so the bolt doesn't turn when you put on the nut, so a normal long bolt won't work really.
Old Jun 28, 2003 | 01:14 PM
crxb16er's Avatar
crxb16er
ehh... thats where i go for everything i need and if not than a u can surely find one at a specialty hardware store that has a wider range of metric nuts bolts, etc. u can also check newhere that sells vw parts they have alot of the same parts surprisingly, this was where i had to find my starter.
